Hello Guest it is April 24, 2024, 12:08:17 AM
Author Topic: Macro for extension G-code  (Read 3391 times)
« on: March 29, 2016, 06:37:25 AM »
There are some Gcode commands that Mach3 can't understand, eg: G68, G69, G72. I have to write a software to translate it to M-codes that Mach3 can understand by Macro (writen by me)
Is there any macro/plugin method for Mach3 to directly understand those Gcodes (G68, G69...)?
(I'm sorry for my bad English)
thanks.
  •  9,199 9,199
Re: Macro for extension G-code
« Reply #1 on: March 29, 2016, 10:28:51 AM »
I don't know about G72 but Mach3 understands the Gcodes G68 & G69 just fine.
« Last Edit: March 29, 2016, 10:32:36 AM by Tweakie.CNC »
« Reply #2 on: March 29, 2016, 11:34:26 AM »
I mean that how we can define some Gcodes that aren't known by Mach3 (not Mcode)
  •  9,199 9,199
« Reply #3 on: March 29, 2016, 11:45:35 AM »
It may be helpful if you could explain the reason why you need to do this.
For example, why would you want Mach3 to understand G72 ?
« Reply #4 on: March 29, 2016, 12:11:16 PM »
I'm using Mach3 to control an old CNC turret puch. There are some Gcode commands for turret puch in .tap file that Mach3 cannot understand (eg: G66I115.J180.P-20.Q-20.D0T256C315) . So I had to write a software to translate these commands to a series of base code (eg: G0 x y, M500) and save to another .tap file. The translated file then can run by mach3
« Reply #5 on: March 29, 2016, 07:09:46 PM »
Different software controllers have similar but not exactly the same, some additional codes and some less gcode codes, AND like a language the dillect can be slightly different for commands. Mach is Mach and others are others. So it was done and so it is. That's just the way things are!
