Hello Guest it is April 19, 2024, 09:30:12 PM
Author Topic: Router/Mill Design & Build  (Read 15477 times)
« on: March 22, 2016, 05:03:33 PM »
Been busy of late and the conversion of the Seig X1LP super has been succesfull to date, now time to build something from scratch. Started badly as I couldn't resist a bargain and came across a couple of sets of Rails Bearings and screws at the right price Sub £300 delivered. So my starting point now is:
4@ SBR20-300mm Linear guide
4@ SBR20-600mm Linear guide
4@ SBR20-1000mm Linear guide
24@ SBR20UU Linear blocks
2@ SFU / RM 1605-350mm- C7 ballscrew with end machined
2@ SFU / RM 1605-650mm - C7 ballscrew with end machined
2 SFU / RM 1605-1050mm- C7 ballscrew
2@ with end machined
6@ BK12 support for ballscrew
6@ BF12 support for ballscrew
6@ Couplings
Major considerations, I have a workshop in a spare room in my first floor flat so everything gets carried up and down as required, and I try to limit noise to be considerate to neighbours. Been looking at Fusion 360 which I find simple and straightforward to use with the Seig conversion so knocked up a quick mock up of a machine to get some comments and advice sure there are lots of traps I have fallen in to pictures below .
My requirements call for a 700x400mm work area and max 100 mmZ axis. Not included in pictures are 2 SFU / RM 1605-1050mm- C7 ballscrews driving Y axis, either 1 or 2 SFU / RM 1605-650mm - C7 ballscrew driving X axis and single SFU / RM 1605-350mm- C7 ballscrew driving Z axis with a Chinese 2.2 water cooled and VFD. A lot of my strength I am relying on a solid base I intend to bolt whole thing solidly down onto a welded steel framed table with a solid cast iron top.
Click image for larger version.  Name: CNC.jpg  Views: 19  Size: 93.9 KB  ID: 17984Click image for larger version.  Name: cncB.png  Views: 17  Size: 101.2 KB  ID: 17985Click image for larger version.  Name: cncF.png  Views: 12  Size: 47.2 KB  ID: 17986Click image for larger version.  Name: cncS.png  Views: 18  Size: 43.0 KB  ID: 17987Click image for larger version.  Name: cncT.png  Views: 13  Size: 75.5 KB  ID: 17988
Material wise two bed sides are100x100x10mm T section which can be backed up by another 25-35mm plate without losing work area, X and Z main components 25mm and 30mm Ecocast, first draught so nothing much fixed apart from overall size, my idea is based on ease of build, welding in the flat is not an option, also the materials used in the design are already in stock so using them is a no brainer.
« Last Edit: March 22, 2016, 05:05:09 PM by lucan07 »
Re: Router/Mill Design & Build
« Reply #1 on: March 23, 2016, 11:39:04 AM »
Time to reflect and rethink design a bit of input from others so a few changes made.
Knocked up version 2 this is a draft few peices omitted till I collect stock material acquired today like side of gantry just turned original on side for now and nor bothered actually mating same to bearings more for concept than actual design, also brackets mounts for screws, motors etc missing.  Hopefully overall design and more importantly rigidity improved pics below sides now 6x2x1/4" Aluminium Box, cross member on X axis now original 150x30mm Backed by 2@3x1x1/4 Angle faced to 75mm x 25.4 to fit.
« Reply #2 on: March 25, 2016, 02:36:56 AM »
Your design looks like it would make a good machine. But a word of advice, since you are building your own: start TODAY writing an Owner's Manual, and list everything you do, as you go. The sources you used for all parts, and components, as well as the drawings you have done, with actual dimensions of each component. Trust me on this, in the future, you will be glad that you took the time to create the book to refer back to. You should include screen captured images for all software settings, so that you will have all of the information readily available to refer back to, when making any future changes or upgrades. Good luck, and have fun!
-Michael
« Reply #3 on: March 25, 2016, 07:02:25 AM »
I design in Fusion360 using (Dimensions & Description)  in (Sketch/Body & Component) naming conventions that document the project, a few comments and pictures of machining assembly steps and most of my projects can be replicated or amended by anyone. As an IT consultant building bespoke systems since the late 80's you're preaching to the converted I over document everything in a manner suitable for Idiots as they usually were!
« Reply #4 on: April 06, 2016, 04:58:50 PM »
First chance to do any work on build today half a day off so made a start, first job decide what to do about the steel and cast iron base I intended on using, top has been ground flat and its ready to go but Base weighs in above 3Cwt and Top just over 4Cwt all to be carried upstairs.
For time being I am going to put base into my lock up and try a different base to as all work in flat is likely to be lightweight, I will be selling my flat and buying a property with a workshop so the base will either be used then with this machine I originally designed for it or with version 2.0 which I have no doubt will be built.
So alternate base? As welding out of question in flat I have gone for simplicity, two sheets of 25mm MDF to make my base, bed laminated 75mm MDF whole base sealed glued and screwed, it's solid, time will tell if its solid enough, I cannot see any problems with type of work it will do whilst in the flat.
As base was drying I decided to drill and tap side rails which are 6"x4"x1/4" Ali box I used M6 with 30mm washers to attach rails to bed, M4 to mount external supporting ribs 300mm 38x38x6mm T section, M4 again to mount 20mm supported rails quite happy with the afternoons work, rails have a little adjustment available and I intend on locking them down with either loc-tite or epoxy when final adjustments made, currently as close as I can measure having just dropped them on and pinched up they are within 0.5mm over 1000mmm on the parallel.
Couple of pics below showing latest design and progress.
« Reply #5 on: April 07, 2016, 04:06:36 PM »
Made a start on the X axis biggest lump thats been machined on the Seig since conversion, think I upset the seig when I put the fly cutter on to true and parallel top and bottom for rails, it started spitting needlles at me with a vengance!
635x150x30mm Plate backed by two lengths of 3x1X1/4" angle which was drilled and plate drilled and tapped for M4, top and bottom trued and drilled and tapped M4 again to mount rails.
Stomache was thinking throat had been cut so stopped now to eat, just two end to machine true and parrallel and main crossmember is about ready for ends to be mounted, thinking pocket the gantry sides 1/16" to accept crossmenber for strength and ease of alignment.
Spindle and VFD just arrived got a good deal on these £146 delivered and they look ok now I'm cooking with gas.
« Last Edit: April 07, 2016, 04:09:01 PM by lucan07 »
« Reply #6 on: April 08, 2016, 01:01:35 PM »
Have a Y and now almost an X and I have a few spare hours over the weekend to come up with working drawing for Z and start machining. Impressed with Fusion360 so far  simple to use and with a little tinker of the code before running mach3 the little seig conversion goes about its business with little complaining, nice to get some decent size lumps on it to cut eventually and make some decent chips.
Ended up pocketing 4mm each side to centre the gantry raiils onto Y axis bearings. the work area I will be able to use now confirmed as minimum 780x450x100mm
« Last Edit: April 08, 2016, 01:03:20 PM by lucan07 »
« Reply #7 on: April 12, 2016, 05:32:16 PM »
Managed to get a couple of hours in over the weekend, and made some progress with Z axis, now have three smooth free moving axis and screws mounted for Y and Z still waiting on delivery of some parts so limited to working with parts already available. Time to start thinking about motor sizes required, being a novice I was surprised by the weight accumulation with the 20-30mm 5083 plate, rails, ballscrews etc used so need to work out totals and ensure adequate power from steppers drivers etc.,
« Last Edit: April 12, 2016, 05:42:33 PM by lucan07 »
« Reply #8 on: April 28, 2016, 04:18:36 PM »
Progress being made not been able to keep up with posts as everything has been done in snatched moments as and when the free ones occured, all wired and connected ready for a test run tomorrow work permitting. Went with 5 axis BOB, 4 x DM542 4.2a drivers, 4 x 425oz Nema 23, 2.2kw HY VFD and Spindle, linkage I used 2:1 ratio from motors to 1605 ballscrews, power supply a pair of 36v 9.7amp units I had, option to swap in a pair of 48v 10.4amp will be available soon if it will be beneficial.
« Reply #9 on: April 29, 2016, 06:14:30 PM »
So much for a day off only ended up working till 9pm, had to plug it in a try it when I got back, spindle fine, Z axis fine, Y axis with A slaved no problem, X axis just a rumble and rock from motor, too tired to even think about it tonight can't be too serious it didn't go bang! The two working axis have proved already it has all the speed I will ever be able to use in the flat and then some if it lived in a shed the shed would have been rocking. Would have been nice to have it all work but 4 from 5 is better than a kick up the backside.
