Hello Guest it is October 14, 2026, 03:26:28 AM
Author Topic: Set Variable to Current Axis Position in G-Code  (Read 13268 times)
« on: March 12, 2016, 10:12:06 AM »
I would like be able to assign the current Y position to a variable in G-Code. This variable would be updated at various points throughout the program. Something similar to the %(2) function in ShopBot. Is this available via a G or M Code, or is this something that would require VB and some type of GETDRO function?
Depending on the options available, what is considered "Best Practice" for accomplishing this in Mach3?
-Thank you.
Re: Set Variable to Current Axis Position in G-Code
« Reply #1 on: March 12, 2016, 01:52:32 PM »
Create an M code with VB Script, and call the M code in your g-code.
« Reply #2 on: March 13, 2016, 02:33:49 PM »
Thank you. I have created a macro M801 with the following.
Dim Yaxis As Integer
Yaxis = 801
SetVar (60,Yaxis)
In my G-Code I have a variable (#60) that represents the YLoc. At the time of the call to M801, will the #60 var will be updated with the current Y axis location? As I call M801 later in the program the #60 var will reflect the new location?
I appreciate the help with this.
« Reply #3 on: March 13, 2016, 04:06:58 PM »
Is your Y axis value actually going to be an integer, or are you trying to round it off to one? SetVar is expecting a double, so you might get a type mismatch if you try it that way.
Try:
Dim YAxis
Yaxis = GetOEMDRO(801)
SetVar(60,Yaxis)
The answer to both of your questions is yes, it should.
