Hello Guest it is March 28, 2024, 03:54:25 PM
Author Topic: 5 axis kinematics plugin now available  (Read 53844 times)
Re: 5 axis kinematics plugin now available
« Reply #10 on: April 17, 2016, 07:20:15 PM »
thank you tweakie  ;D
not still available for downloading, coming soon
« Reply #11 on: August 20, 2016, 08:38:38 AM »
Very nice work. This gives me one more reason to finish up all of my outside work so I can concentrate on my machines this winter.
 I can't wait until it is available for download and testing.
Mike
« Reply #12 on: August 20, 2016, 06:23:12 PM »
Hi Mike,
thank you.
The final version of the A/C table-table 5 axis plugin will be available soon.
some fixes and improvements have been made.
It will be followed by a beta B/C rotary head.
Test OK by a guy, so that it was a good new for me.
Richard.
« Last Edit: August 20, 2016, 06:36:30 PM by krw125 »
« Reply #13 on: August 21, 2016, 02:04:30 PM »
Super great news for 5 axis B/C head - doughty drive head!
I've been working on this this machine design, and now I finally now that it could might come to like thanks to your plugin.
Keep up the good work!
« Reply #14 on: August 21, 2016, 02:07:40 PM »
Will be there a similar plugin for Mach4?
« Reply #15 on: September 04, 2016, 09:46:10 PM »
Hi
I downloaded the plugin from http://mach3fiveaxis.top-eb.fr/ last week to try it out.
As soon as I run it from the Plugin Control it just crashes Mach3. Does any one else have this problem?
I have tried on 2 different PC's and they both crash.
I am running Mach3 on Win7 and that is working fine.
Paul
« Reply #16 on: September 04, 2016, 10:59:15 PM »
Hi Paul,
On win7, you  can try to run it in winxp compatible mode.
But this is an older version (the first). Since some errors have been fixed  but it have not been put online for downloading.
Richard
« Reply #17 on: December 05, 2016, 11:55:47 PM »
What is the current official status of the plugin? Also, is it compatible with the CSMIO controller?
« Reply #18 on: December 06, 2016, 02:10:11 PM »
Hi penkomitev,
Thank you for your interest, it's important for me.
About A/C table version, currently in stand by because the B/C head version is in development and it take a lot of time. After i will return to A/C version.
The good new about the B/C head version, it should be available in few days. The time also to add one or two pages on my website becouse there are some things to show.
As the head is tiltable it was necessary to remake movements in the tool axis.
To know
- Movements in the perpendicular plane of the tool axis with display of the position of the tool tip in this plan
- Movements in the no perpendicular plane of the tool axis with display of the position of the tool tip in this plan
- Drilling cycles : G81 G82 G83 G99 G98
- Tool length compensation G43
- Tool radius compensation  G41 G42 in perpendicular plane of the tool axis
- enable RTCP G43.4
- disable RTCP G49
- Display Toolpath in the simulation screen
- Display Toolpath with G41 G42
- Offset of the origin in the work plan (perpendicular plane to the tool axis or no perpendicular plane to the tool axis)
- Label, subprogram call by label, label loop, loop and  imbricated loop
- MDI commands
- Editor
- Tool library
- Simulation with different forms of tools : cylindrical, spherical, conical, dovetail, T slot.
So, all in details, soon on my website.
Best regards, Richard.
« Reply #19 on: December 06, 2016, 02:35:31 PM »
Sorry,
actually, not tested with other controller card, just tested with LPT port.
thanks
