Hello Guest it is April 24, 2024, 06:54:37 PM
Author Topic: Offset malfunction  (Read 10241 times)
Offset malfunction
« on: February 27, 2016, 02:27:21 PM »
I wonder if anyone experienced similar problem with offset.
I loaded PLT file from CorelDraw to LC. While saving GCode for offset some strange paths appear on the screen. I went through the manuals and tutorials but nothing helped.
Any suggestions appreciated.
Re: Offset malfunction
« Reply #1 on: February 27, 2016, 02:35:22 PM »
Here are pictures of what I was talking about.
  •  9,199 9,199
« Reply #2 on: February 28, 2016, 02:58:20 AM »
The 'Crop Circles' have appeared because you have the incorrect IJ Mode set.
In Config / General Config change the IJ Mode then regen. toolpath.
This problem occurs because Mach3 caters for two different methods of defining arcs (Absolute and Incremental) as different CAD/CAM packages may use either of these different methods. Ideally your CAD/CAM generated Gcode should include the G90.1 /G91.1 (as appropriate) but alas it does not always happen. LazyCam was abandoned many years back and nowadays there are much better packages available - some are free but like all things 'you get what you pay for'.
Hope this helps.
« Reply #3 on: February 28, 2016, 10:55:14 AM »
Thanks Tweakie, your advice helped.
IJ Mode had to be changed.
I bought SolidCam but would aslo like to try any free package. Which one would you recomend?
Regards
Hofi
  •  9,199 9,199
« Reply #4 on: February 28, 2016, 11:35:22 AM »
There are so many to choose from you will just have to look around. It's a few years ago now but I used G-Simple when I started out http://gsimple.eu/
