have you read the appropriate manuals here: http://www.machsupport.com/help-learning/product-manuals
Here's some tips on what you need to be reading up on.
You'll need to understand how to read the 3 ports of a parallel port i.e. the data, control and status ports.
You'll then need to understand how to mask out the appropriate bits and then use those values to set or clear user LEDs.
All this will need to be done in a loop so you'll need to understand the macro pump.
yes, there is lots to learn... I was idle in this
I thought it is a short cut to learn from otherone's screenset file, so....
I konw sometime the user button and user DRO need user script
But the screenset which I learn from(SwissU) has no script for the parallel port pin LEDs
so now... I think the userLED of oem-code 1855 to 1888 is defaults to belong to parallel port pins state, such as the LED of oem-code 137 to 160
THANK YOU , I will goto learn more
