I am a little confused, most of what I am reading is referring to an analog connection between the HICON board and The Teco 7300CV VFD.
I am changing from a different control software (millmaster) to Mach 4,
From a different Motion control board (mn400) to HICON Integra board
Currently the VFD is connected to PC over serial, not an analog wire. When I switch to the hicon and Mach4 will the VFD still be controlled over serial, or do I need to get it working over analog? Does one method have advantages over the other? At first glance to me, the serial seems like the better control interface. How do I set this up? The VFD is already working well with the old setup.
