Hello
Guest
it is
April 19, 2024, 04:10:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
Screen designer tips and tutorials
Screen4 strange behaviour
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Screen4 strange behaviour (Read 5502 times)
TadyTheFish
21
on:
February 04, 2016, 09:01:25 AM »
Hello im trying to edit some screens in Screen4. When i open a lset file i san select buttons and images in the screen, but as soon as i move a button i can't select it anymore.
Does anyone else experience this strange behaviour?
im using Win 8 and the latest Screen4
Thank you!
Logged
ger21
6,295
Re: Screen4 strange behaviour
Reply #1 on:
February 04, 2016, 09:05:16 AM »
Are there scroll bars in the design window? If so, you'll have a lot of issues with Screen 4. If the entire screen does not fit in the Screen 4 design area, than it can be very buggy. You might want to look into Mach Screen.
Logged
TadyTheFish
21
Reply #2 on:
February 04, 2016, 09:36:59 AM »
yes there are scrollbars. im usin 1600x900 screen size.. i will try smaller!
i have Mach screen but i have other problems with it! One time i opened the program the work area just dissapered .. only the little editing window opens... can't do anything. i tried reinstalling with no siccess
so i abandoned Mach screen
Thank you!
Logged
Klaus1311
531
Reply #3 on:
February 05, 2016, 03:15:02 AM »
you can hold down the shift key and start MachScreen. Keep Holding the shift down until you see the MachScreen window.
Klaus
Logged
The brain isn't a soap, it doesn't shrink when used.
TadyTheFish
21
Reply #4 on:
February 05, 2016, 04:02:55 AM »
Not working... I get An error a few times. Parameter is incorrect
Logged
Klaus1311
531
Reply #5 on:
February 05, 2016, 06:47:45 AM »
delete registry key HKEY_CURRENT_USER\SOFTWARE\KD-Soft\MachScreen
Logged
TadyTheFish
21
Reply #6 on:
February 05, 2016, 07:07:05 AM »
It worked!!! Thank you so much!! I need to write down this fix if it stops working again!
Thank you!
Logged
Klaus1311
531
Reply #7 on:
February 05, 2016, 09:22:23 AM »
You don't have to. I'll release a Version where you can do that using MachScreen's menu
Klaus
Logged
Print
Pages:
1
Go Up
« previous
next »
