Hello Guest it is April 26, 2024, 01:38:58 AM
Author Topic: Problems starting up with lazyturn  (Read 16164 times)
Re: Problems starting up with lazyturn
« Reply #10 on: January 27, 2016, 02:00:43 PM »
Oh BTW,
There is a manual for LT. Read it and don't hack the program.
« Reply #11 on: January 27, 2016, 02:18:56 PM »
The manual was written by me almost 6 years ago, so yours truly had to go back and have a look at it! :D
Did you install LT per page 6 in the manual?
Again can't help on the Win 10 stuff....I am still at XP and Win 7. :)
« Reply #12 on: January 27, 2016, 06:53:00 PM »
Rich thanks for your answer again.
I installed lazyturn directly out of the download area of mach3.
I suppose that that is the best (and latest) one to install.
Perhaps it is best that I try  it again on a computer with windows 7 OR xp on it.
I have the funny idea that I am still doing something wrong.
Is it possible that i can report to you by a photograph every step I make and perhaps you can recognize a mistake I make.
(the only problem is that every photo represents 3,5 Mb so that I have to sent it to you in perhaps 10 separate replies.)
Or is there another way to deal with this?
On forehand thanks for your help
« Reply #13 on: January 27, 2016, 07:08:16 PM »
The reason I mentioned the installation per the manual is that if LC is not per the stated version LT may not work properly
and I don't know what is in the download section. So the safest bet is to check versions of both LC & LT that you installed.
??  About will display the version.
I am not really sure you are doing anything wrong. I have a good example in the manual and one can use the dxf file provided
and just follow what I did. You should end up being able to post the gcode.
If you can try it on W7 or XP if you can.
« Reply #14 on: January 28, 2016, 04:02:10 AM »
Rich,
Lazycam is version 3.0 and lazyturn is version alpha 1.1
Are these the latest ones?
Kind regards,
Andre
« Reply #15 on: January 28, 2016, 06:32:44 AM »
LazyCam  needs to be LazyCam Version 3.00.2.
LazyTurn should be  LazyTurn Release 1.1.
I believe that is the problem since you are missing files.
See page 6 in the LazyTurn Manual.
« Reply #16 on: January 28, 2016, 04:58:03 PM »
Rich,
I installed lazycam 3.00.2 and lazyturn 1.1 now the toolpath is visible (roughpass only) the simulation works BUT the after clicking PST the only gcode which are shown is : Firts post en G20 ----nothing else the saved file remains empty.
The right working space shows:
LazyTurnProject
tonrond.dxf
Stock diameter: 7.8202
Start Stock Volume : 367.970 mm^3
Display in diameter mode
Display in mms
Toolpath
Rough profile
perPass : 0.1000
Feedrate : 1000
Tool: TOOL 1 -R0.5000-IC4.000
Toolpost#: 1
Thats all
Fine pass not in the upper toolbar and when you click on Toolpath > fine path it gives a comment that it is not implemented.
Any idea what is wrong??
Kind regards,
Andre
« Reply #17 on: January 28, 2016, 06:59:21 PM »
Why not just Duplicate  what shown in the manual, starts at page 37 so that all the toolpaths are created.
This way I know that the info is there to post.
If you use Skype we can set up something, but I will say this.....
Everything I know about LazyTurn is in that manual.
« Reply #18 on: January 28, 2016, 09:50:30 PM »
I just installed Lazyturn on my win 10 computer and had the same problem
Try this. It has been so long since I did it i had to search for the solution again.
http://www.machsupport.com/forum/index.php/topic,15727.0.html
« Reply #19 on: January 28, 2016, 10:24:44 PM »
Andre, Mike and anyone else .......................
I would appreciate if  you can try the fix as posted in the link / reply #18 for Win 10 and if possible also Win 8.
Unfortunately I don't use now, or plan in the near future, to run either of those Windows versions.
Post back here how things went,
Appreciate it,
