Hi Ian,
I did a little testing.
Ram is 2" dia. x 8" long, about 7 lbs.
Cylinder is 2.5" bore x 2" stroke.
Pics show the cyl extended with the recoiled gap and the "internals". Will experiment with various springs as it looks to provide a more than adequate wallop. Yep, all them clamps ARE necessary. Even slid them slightly.
Pretty well instantaneous but there is a little oscillation as the spring settles out right after the slam. But I think it will be well clear of the material ... hope so. Might need to figure a way to dampen it without affecting the recoil speed.
Its a bit worse when vertical.
Tried to do a vid, I need luck with that.
Next, I'll set up some actual cutters, too busy right now.
Russ
dang video is too large. Will get another.
