Hello Guest it is April 26, 2024, 03:21:49 AM
Author Topic: Logic failure, help please  (Read 3310 times)
Offline Davek0974
  •  2,606 2,606
« on: January 12, 2016, 01:24:00 PM »
I have a #var being set to 1 or 0 via G-code.
I have a brain that switches an output IF two conditions are met -
The #var being = 1 AND the RUN(804) LED being on i.e. we are running code.
However the logic fails as the output is triggered when I load a g-code file OR when doing a path regeneration.
Any reason why this should fail and is there a way to make it work??
Re: Logic failure, help please
« Reply #1 on: January 12, 2016, 02:30:17 PM »
Check your other post on this I posted a new brain to try.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: January 12, 2016, 02:30:45 PM »
Ok, thanks, got it.
