Hello Guest it is April 24, 2024, 03:05:53 PM
Author Topic: IP-A and Linear Scales / Encoder not directly on motor - how?  (Read 11884 times)
Re: IP-A and Linear Scales / Encoder not directly on motor - how?
« Reply #20 on: January 19, 2016, 12:56:26 AM »
Chaz,
Your mill looks like a real gem. Didn't recognize the original control, is it a Fanuc? Also, who manufactured the mill? Again, looks like a gem of a machine. Looking forward to seeing the results of your retrofit! The link to the air bearing lathe is fascinating. Thanks for sharing that.
Mike
Offline Chaz
  •  48 48
« Reply #21 on: January 19, 2016, 03:53:39 AM »
Chaz,
Mike
Hi, its not my mill, doing it for someone. It has (had) something called Control Techniques FNC4. Looks like a MS Dos based PC solution bringing all the neccessary cables / information back to a multitude of interface boards. Not sure if I can cross link to the my cnc forum images, but this is it.
Offline Chaz
  •  48 48
« Reply #22 on: January 24, 2016, 03:03:34 PM »
So, retrofit mostly done. Space is tight, especially since we added the mpg module and took up more space.
Z height finish is flawless. Not that impressed with finish but the cutting strategy was crapped and rushed. Not a bad little machine.
Just uploading a vid ....
« Reply #24 on: January 25, 2016, 08:37:53 PM »
Nice job on the retrofit install, looks neat and tidy despite cramped quarters. Results look good!
Mike
« Reply #25 on: January 29, 2016, 05:24:38 PM »
Looks good, though not sure if it is just the camera moving about or maybe a bit of tuning needed, axis seem to be overshooting a wee bit.
Offline Chaz
  •  48 48
« Reply #26 on: January 30, 2016, 06:03:56 AM »
Indeed. We have done some more work last night to complete teh wiring. Occasionally get PID errors, perhaps 2000 / 2500 mm/min is too much for this little machine. Really struggling to get the PID turning spot on but its working fairly well. I think the owner would probably want something that could cut quicker. Also having a bit of an issue on the X travel, not sure from what.
