Hello Guest it is April 23, 2024, 06:20:56 AM
Author Topic: Need help with bob I/O and mach3 for plasma table  (Read 3022 times)
« on: December 22, 2015, 10:46:44 AM »
I need help to wire up my db25 bob to work with mach3. Heres what i have so far,output pins 2,3,4,5,6,7,8,9 are x,a,y,z step and direction. that leaves me pins 1,14,16,17 available. input pins 12,13 are thc +,- that leaves pins 10,11,15 open on the inputs. now heres my problem i still have arc okay, x,a,y and z home to wire in but only have pins 10,11,15 open on my bob. can i use output pins for home switches and configure them in mach? thank you for your advice.
Offline Greolt
  •  956 956
Re: Need help with bob I/O and mach3 for plasma table
« Reply #1 on: December 22, 2015, 04:32:31 PM »
Mach3 will handle all the home switches on one input pin.  Wired NC in series
Provided you do not use slaved axis homing.  You would then need A on a separate pin.
Don't forget that you will need ArcOK input.   Also if using a floating head then you will need probe input.
THC+
THC-
ArcOK
Probe
Home switches.
You should get away with that
« Reply #2 on: December 22, 2015, 04:53:48 PM »
With plasma and a stepper machine you really do not need HOME or limits   to do 99% of all your work.
You base all your work from Work Zero and you set that by hand every time you setup a new cutfile.
Do all your Cad/Cam work with 0,0 being lower left and you can't really mess up.
Just a thought, (;-) TP
« Reply #3 on: December 24, 2015, 09:26:15 AM »
Thanks for the replys, im going to run with the basics for now ,thc+,-, arc ok ,and z home for touch & go. thinking i will update to a usb bob after a while which will give me some room to grow later ,pipe cutter plate marker ect.
