Thanks Hood,
since days and I'm not able to upload all the photos!
I have sent the gear name plate, can you find any useful Info that would help with the calculation?
How to get the motor Encoder value? is it written on the motor name plate, or I need to look in the motor manual (which I don't have) ?
UPDATE:
here what I have done to attempt calibrating my rotary "A" axis:
1- I measured the outer circumference of my chuck (1975 mm) and I used Mach3 (Set Steps Per Unit) function at “Setting” tab try and error until I got it somehow“ calibrated”!,
Calibrated means If I used MDI : G1A1975F2000 my chuck would make 1 complete revolution!
is that even legal?
2- Now, do I need to keep he rotary "A" axis as is or I have to converted into "Rotation axis" by doing the following :
a- Config > Tool Path > Rotations > check the A-Rotations Enabled, and check the "Use Radius for Feedrate."
b- Settings" menu > in the upper right corner is for "Rotation Radius." Since you checked the "Use Radius for Feedrate" in the Toolpath menu, here is where the part Radius is entered to make the axis's move in sync. Enter some general value, like 2.00 if you are using "Inches". If you are doing a real job, you should enter the actual part radius. (is this a must every time I make a new pipe cutting)?
c- Under "Config", open the "General Config..." page. On the left side of page is a box "Angular Properties." Check "A Axis is Angular."
How the above setting would conflict or support the SheetCam Mach3 post processor “unitsPerRev=360” parameters.
4- Do I need to install a homing sensor for the rotary Axis "A" ? If not so do I have to Zero the axis form the DRO every time I start cutting?
Would appreciate any comments.
Z
