Hello Guest it is April 26, 2024, 12:12:57 AM
Author Topic: Changing Motor Rotation Direction  (Read 7221 times)
« on: May 09, 2007, 02:39:24 PM »
Hi all,
I've been using Mach3 for a while now, but I haven't really experimented, it just does what I want and I like it!  ;) I did a quick search but couldn't find a thread for this, although I'm sure there probably is one somewhere!
Anyway, I'm building a new machine, and it has a 4th Axis, the A-Axis. This is slaved to my X-Axis as a dual leadscrew design. I slaved the A motor to the X easily in Mach3 but when I use the X jog function, my A Axis motor is rotating in the opposite direction to the X axis, and I can't seem to figure it out. They are all wired up the same. How do I reverse the direction of rotation in Mach3 for a stepper motor?
Thanks all.
Re: Changing Motor Rotation Direction
« Reply #1 on: May 09, 2007, 03:51:32 PM »
I had an issue where everything was coming out reversed on my A axis.  I reversed direction by going into Config --> Ports and Pins --> Motor Outputs and then checking Dir LowActive.
dan
« Reply #2 on: May 09, 2007, 05:59:14 PM »
Thanks Dan, I changed the dir low and active low setting fr the A Axis motor, and she's purring like a kitten now....and in the correct direction! L8rs. :)
Offline GPDC
  •  43 43
« Reply #3 on: May 09, 2007, 07:56:01 PM »
fwiw....another example of the great configurability of Mach
