Hello Guest it is April 26, 2024, 01:43:08 AM
Author Topic: Use probing for tool zeroing  (Read 17103 times)
Re: Use probing for tool zeroing
« Reply #30 on: December 04, 2015, 07:56:40 PM »
ok thankyou for your time in replying.
dtg
No problem.
  •  9,199 9,199
« Reply #31 on: December 05, 2015, 01:42:57 AM »
Offline dude1
  •  1,253 1,253
« Reply #32 on: December 05, 2015, 01:45:33 AM »
to funny
Offline Pedio
  •  200 200
« Reply #33 on: December 13, 2015, 03:31:33 PM »
ok updated to set z axis on probe touch
Code: [Select]
local ToolSetter = 15.7 -- change to your toolsetter height
mc.mcCntlGcodeExecuteWait(0,"G91 G31 Z-15 F40") -- change feedrate and depth to suit
mc.mcCntlGcodeExecuteWait(0,"G91 Z2 F40") -- change feedrate and retract to suit
mc.mcCntlGcodeExecuteWait(0,"G91 G31 Z-3 F10") -- change feedrate to suit
mc.mcAxisSetPos(0, mc.Z_AXIS, ToolSetter) -- set dro to height of toolsetter
mc.mcCntlGcodeExecuteWait(0,"G91 Z5 F40") -- change feedrate and retract to suit, use this Z rectract value for line 7
wx.wxMessageBox("Remove ToolSetter") -- remove if needed
mc.mcCntlGcodeExecuteWait(0,"G90 Z0 F50") -- move tool to zero,  change feedrate to suit
Daz
Daz - Works Great for me. THANKS - this makes my life better!!!
Offline Bronk
  •  12 12
« Reply #34 on: January 09, 2016, 07:27:22 PM »
Thank you. This works great.
This was my first time screen editing and adding scripting. On button added to the tool panel, convert the measurement values from mm to inches and I was off and running.
Huge time saver.
Offline HoY
  •  18 18
« Reply #35 on: March 07, 2017, 06:21:45 PM »
After spending quite a bit of time wondering what I was doing wrong, and changing values over and over again, I noticed that G90 would have my Z axis go down while G91 only let it go up, even when the called for Z command was up. I don't know what the difference is between G90 and G91, but when I changed the two downward probing commands to G90, and everything that is supposed to be Z up left at G91 the script started working properly for me. I imagine it's completely my fault I had to do this. Probably something to do with my Z axis motor mounted upside down and being pulley driven, and axis reversed when mapped.. Anyway, got it working, finally!
