Can someone explain how to use the probing screen for tool zeroing??
Not sure what it's looking for and the "help" buttons on the screen are useless.
There's an option for Z position. I'm guessing this is how far the probe will travel to make contact??
When I click the "Measure Z" button, it just gives an error saying "No contact with Probe" (not exact message), then it disables Mach.
If I try it with soft limits active, I get a PMDX error 7.
The probe is working based on the diagnostics page and the fact that I got the Measure Z to move the axis once, it made contact with my "Z block" (1/4" aluminum), it retracted but then I got the no contact message and it hasn't done anything but give the error since.
I'm using Mach4.2803 on Win7 Pro 32 bit with a PMDX-410 to a G540.
Give me steps if possible and what will the results be? Does it stop at zero like mach3 scripts did?
