Hello Guest it is April 20, 2024, 12:02:59 AM
Author Topic: Xhc HB04 MPG Pendent with Mach4  (Read 79079 times)
Re: Xhc HB04 MPG Pendent with Mach4
« Reply #30 on: June 04, 2017, 06:25:59 PM »
I would love to try that driver out.  I think XHC does not want you to be successful (As hard as they are trying to sell you their motion card :)) .  Let me know which hoops to jump through and I will do my best.
Bart
« Reply #31 on: June 04, 2017, 08:42:45 PM »
Bart
Thanks for your interest.
attachments in these forums are pretty easy to miss :P
I attached a .zip file to a post above that contains the plugin and driver. Just download than follow the README.txt files.
« Reply #32 on: October 09, 2017, 08:30:37 AM »
Thank you for this brilliant software!
« Reply #33 on: October 12, 2017, 10:14:05 PM »
My pendant is on the way.  Please let me know where to find the driver.
Cheers,
Kim
« Reply #34 on: October 13, 2017, 09:15:01 AM »
Cheers,
Kim
Open your eyes, two posts above it is.
« Reply #35 on: November 20, 2017, 06:52:45 AM »
good work for this driver! I tested it and it works fine. But now i have a problem. Im using mach3 at the moment and i tried to go back to mach3 with the mpg. But it don't works. I uninstalled the driver and then reconnected the usb-stick. Windows installed the normal hid driver. But mach3 didnt work with mpg any more
What can i do? Some ideas?
Steffen
« Reply #36 on: December 01, 2017, 12:08:43 AM »
 Sorry, I didn't anticipate someone reverting back to the generic driver and didn't try to run the mach3 driver after a driver rollback.
I'm not sure what is causing this issue and I will install mach3 here and see if i can replicate the issue.
which version of windows are you using?
does moving to another USB port change anything?
perhaps try using  Zadig and experiment with the different winUSB drivers?
also, sorry for not responding right away, I didn't catch your post till just now. (need to check my notification settings)
« Last Edit: December 01, 2017, 12:12:01 AM by mkullman »
« Reply #37 on: December 01, 2017, 02:53:00 PM »
thank you very much! Yes i tried different things to get the mpg working with mach3 again.
Windows: Win10 pro, 64bit
Mach3: Latest Version
Tested:
- removed MPG from device manager, with "remove driver". The reconnected the USB-stick, windows installes mpg as HID again, but with "not migrated message". Not working in mach3
- used some other usb-ports. Not working
- used zadig, tested different settings. Not working
USB Device (devicemanager) says device redy, but:
Das Gerät USB\VID_10CE&PID_EB70\6&3b560980&0&3 wurde aufgrund einer teilweisen oder mehrdeutigen Übereinstimmung nicht migriert.
ID der letzten Geräteinstanz: USB\VID_0000&PID_0002\6&22bce1d6&0&3
Klassen-GUID: {36FC9E60-C465-11CF-8056-444553540000}
Speicherortpfad: PCIROOT(0)#PCI(1A00)#USBROOT(0)#USB(1)#USB(3)
Migrationsrang: 0xF000FFFFFFFF0103
Vorhanden: false
Status: 0xC0000719
« Reply #38 on: December 03, 2017, 08:53:18 PM »
Its my understanding that MACH3 does NOT work on Win 10.  Is that not true?
- Robert Beaubien
- Drone Plastics
“Dear Algebra, Please stop asking us to find your X.  She's never coming back and don't ask Y.”
« Reply #39 on: December 03, 2017, 08:54:58 PM »
Mach3 works fine with Windows 10 - you just need a Motion Controller. Parallelport is not working
Steffen
