Hello Guest it is March 29, 2024, 08:31:27 AM
Author Topic: Xhc HB04 MPG Pendent with Mach4  (Read 78656 times)
Re: Xhc HB04 MPG Pendent with Mach4
« Reply #20 on: March 08, 2017, 10:06:46 AM »
Just got mine in today.
Could you share the driver with me please.
Many thanks in advance.
« Reply #21 on: March 08, 2017, 08:56:02 PM »
 >:D >:D >:D
Asked for it.
Got it.
Installed it which is a breeze ( for a more advanced user )
hooked it up.
worked like a charm!!!
@mkullman  you totally rock dude!!!
And i really bought this mpg cause i seen this post before.
So the guys that produce these should thank you cause they made a sale because of it.
« Reply #22 on: March 08, 2017, 10:00:44 PM »
Glad to hear!
let me know if you can think of any improvements
« Reply #23 on: March 09, 2017, 08:01:13 AM »
Are the macro's working ??
I did not test it.
Still would be nice if i could just go in that script and changed the macro for button 1 or 2.
would use it to find my X Y zero and my center hole with my touch probe :p
« Reply #24 on: March 10, 2017, 12:03:38 AM »
I have not yet had a use for the "macro" functions, so I have not tested them myself. But I did set "Macro 1" to regenerate the tool path and I did map the rest to Mach "input" signals.
I did verify that the signals are indeed being thrown in the Mach GUI though.
In theory you should be able to trigger Lua scripts from the signals. From there, you should be able to write any "macro" you want.
« Reply #25 on: March 10, 2017, 03:16:27 AM »
Awesome :p
« Reply #26 on: April 09, 2017, 12:37:37 PM »
Hi
Could I also get the driver?
You have done amazing work with it.
« Reply #27 on: April 09, 2017, 02:32:01 PM »
I believe I've had enough users test this that I am comfortable posting the driver here for all.
The attached Zip file contains the latest version of the plugin. ENJOY ;D
if you have any questions or issues, feel free to pm me
moderators, if you believe I should post this under another section of the forum, please advise.
  •  9,196 9,196
« Reply #28 on: April 10, 2017, 01:39:52 AM »
Excellent work Mkullman.
« Reply #29 on: May 14, 2017, 09:15:35 PM »
Awesome work  mkullman.... I used this pendent with mach3 and it worked great.... thank you very much!!!
