Hello Guest it is April 26, 2024, 10:31:39 AM
Author Topic: Check out my temperature Sensor and Mach3 controller  (Read 4167 times)
« on: November 06, 2015, 12:08:20 AM »
I currently have my Gecko controller in a nice, fan cooled Bud Box and can monitor the temp with a standard temperature sensor and display, but I was always concerned that if the Gecko over heated, I may damage the unit. Soo.... I build an Arduino temp sensor that interacts with the Mach3 controller via a USB cable.  Basically, if the unit gets to 60 degrees, it cuts the feed by 50% in an attempt to reduce the heat load. If the Gecko still manages to get to 70 degrees, it cuts all motion and turns off the router.  Then it waits for the temp to fall below 60 degrees before turning the router back on, brings the feed speed back up, and resumes cutting.
Early prototype video:
https://www.dropbox.com/s/rs663peo4z80kan/IMG_1979.MOV?dl=0
  •  9,200 9,200
Re: Check out my temperature Sensor and Mach3 controller
« Reply #1 on: November 06, 2015, 02:23:37 AM »
Excellent work Andrew.
