Hello Guest it is April 20, 2024, 12:19:01 AM
Author Topic: mcX360 Mach4 Controller Plugin  (Read 21539 times)
Re: mcX360 Mach4 Controller Plugin
« Reply #30 on: September 18, 2017, 06:57:36 AM »
DazTheGas has everything you need to make the Xbox controller work with Mach4. Watch his videos.
« Reply #31 on: September 18, 2017, 08:05:54 AM »
Yeah i'm not into writing script as its too hard for me.  I was looking for something with a configuration screen built in like it is on Mach3 ? Why cant there be a configurator made for Mach4 ?
« Reply #32 on: September 18, 2017, 09:07:18 AM »
Send me a message at francocncprojects@gmail.com I have some information you may want to look at.
Offline Klaus
  •  42 42
« Reply #33 on: July 10, 2018, 05:15:43 PM »
Where can I find his Video?
Offline DazTheGas
  •  778 778
  • DazTheGas
Offline Klaus
  •  42 42
« Reply #35 on: July 10, 2018, 06:52:30 PM »
Great thanks :)
So is the Plugin for Xbox360 working on the latest version of Mach4?
Thanks.
« Reply #36 on: June 30, 2023, 08:49:26 PM »
@DazTheGaz: Thank you for putting the xbox Plugin out there! It's been really helpful!
I'd like to understand the following:
I run into a jerky motion (kinda break slam) when using the xbox controller and attempting to jog incrementally afterwards.
It is replicable:
1. Preposition XYZ with xbox controller
2. Switch to jogging on screen (incremental) , and jog Z- in -0.1mm steps down
If I manually change the jog override (no matter if from say 25 to 50% or vice versa) after the prepositioning, the issue does not appear.
Thank you so much! Michael
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #37 on: July 25, 2023, 03:43:11 PM »
Have you tried the Xbox360 plugin that is now bundled with mach4 ??
DazTheGas
