Hello Guest it is April 25, 2024, 04:09:07 AM
Author Topic: hicon session id mismatch  (Read 2871 times)
« on: October 31, 2015, 04:27:53 PM »
I have my hicon hooked up to power 24vdc and 5vdc and hooked up to the ethernet and can see the hicon at ip 1921.168.0.35.
but when I start mach3 I get and error:
Sat - 15:09:06 ---HiCON: Plugin: 1.36.7, Board: 7766, FW 3.12, Serial 8BD8FC, FPGA: 7E7B, IP 192.168.0.35
Sat - 15:09:07 ---ERROR: Connection to HiCON lost. Session ID Mismatch
I have tested my cable and it checks out fine
CPU led double flashes red
+24v led is green
ARM  led off
+5v  led green
What am I missing?????
Jerry
« Last Edit: November 01, 2016, 12:50:02 PM by Vital System Support »
Re: hicon session id mismatch
« Reply #1 on: October 31, 2015, 05:41:14 PM »
please use the plugin and firmware available on the hicon integra web page
www.vitalsystem.com/integra#downloads
and click on the Integra Mach3 Plugin and Firmware.
The default firmware shipped these days is for mach4.  so you will need to update to the plugin and firmware available in the above download.
thanks
VSI Support
« Last Edit: October 31, 2015, 06:35:32 PM by Vital System Support »
