Hi
I tried SDK 2.62 with visual studio, but i got the following error,
1>------ Build started: Project: MachDevice, Configuration: Debug Win32 ------
1>Build started 10/4/2015 11:38:55 PM.
1>InitializeBuildStatus:
1> Touching "Debug\MachDevice.unsuccessfulbuild".
1>Midl:
1> All outputs are up-to-date.
1>ClCompile:
1> stdafx.cpp
1> G100Part.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Part.cpp': No such file or directory
1> G100Helpers.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Helpers.cpp': No such file or directory
1> G100Handler.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Handler.cpp': No such file or directory
1> G100Enumerator.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Enumerator.cpp': No such file or directory
1> XMLProfile.cpp
1>c:\cnc\mach3development\sdk.2.62\g100io\xmlprofile.cpp(55): warning C4996: '_itow': This function or variable may be unsafe. Consider using _itow_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1> c:\program files\microsoft visual studio 10.0\vc\include\stdlib.h(645) : see declaration of '_itow'
1> MyHandler.cpp
1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): error C3500: invalid ProgID 'ShockwaveFlash.ShockwaveFlash'
1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): fatal error C1103: fatal error importing progid: 'ShockwaveFlash.ShockwaveFlash'
1> Monitoring.cpp
1> MachDevImplementation.cpp
1> MachDevice.cpp
1> LocalIPQuery.cpp
1> GRexControl.cpp
1> G100General.cpp
1> G100FLASHCONFIG.cpp
1>c:\cnc\mach3development\sdk.2.62\g100io\g100-structs.h(1): fatal error C1083: Cannot open include file: 'g100.h': No such file or directory
1> G100Config.cpp
1> Generating Code...
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:09.59
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Which sdk works with visual studio 2010?
or how to remove this error?
