Hello Guest it is July 21, 2026, 10:58:41 PM
Author Topic: CNC Lathe turret tool changer help?  (Read 68706 times)
0 Members and 4 Guests are viewing this topic.
Offline mike^3
  •  116 116
« on: October 07, 2015, 03:06:28 PM »
 ;D I appreciate all help!!!
Hello everyone! I am retrofitting my CHNC4, I am working on the lathe portion now. Currently there are 4 wires coming off the lathe encoder.
Here is the output states of each wire to what tool it is at.
Output 6 is the output to start and stop the turret.
Tool   pin 2   pin 3   pin 4   pin 5
1   1   0   0   0
2   0   1   0   0
3   1   1   0   0
4   0   0   1   0
5   1   0   1   0
6   0   1   1   0
7   1   1   1   0
8   0   0   0   1
Here is the script I started. However I have 2 questions:
Question #1: What do I need to add to the script to update the current tool and tool offset to reflect selected tool?
Question #2: How would I be able to compare the signals for example when I get to tool 7 when pin 2,3, and 4 are HI? To tell mach, yes you are at tool 7 because all states are HI? I tried to put Active1 & active2 etc etc when the 2 or more signals need to be compared. However when I emulate an active state on those inputs, mach does not activate output6 or stop when I hit the emulated key (it shows on the diagnostic screen that it is active when I hit the key)
If GetSelectedTool() = GetCurrentTool() Then
     message("Tool is the same NO tool change needed")
   END
    End If
 If GetSelectedTool = 1 Then
 Message "Moving to Tool# " &GetselectedTool()
    Do
     ActivateSignal(OutPut6)
   If IsActive(Active1) Then Exit Do
   Loop
    DeActivateSignal(Active1)
       Message("Tool#1 Loaded")
   End If
 If GetSelectedTool = 2 Then
    Do
   If IsActive(Active2) Then Exit Do
   Loop
    DeActivateSignal(OutPut6)
   End If
 If GetSelectedTool = 3 Then
    Do
   If IsActive(Active1) & IsActive(Active2) Then Exit Do
   Loop
   End If
 If GetSelectedTool = 4 Then
    Do
   If IsActive(Active3) Then Exit Do
   Loop
   End If
 If GetSelectedTool = 5 Then
    Do
   If IsActive(Active1) & IsActive(Active3) Then Exit Do
   Loop
   End If
 If GetSelectedTool = 6 Then
    Do
   If IsActive(Active2) & IsActive(Active3) Then Exit Do
   Loop
   End If
 If GetSelectedTool = 7 Then
    Do
   If IsActive(Active1) & IsActive(Active2) & IsActive(Active3) Then Exit Do
   Loop
   End If
 If GetSelectedTool = 8 Then
    Do
   If IsActive(Active4) Then Exit Do
   Loop
   End If
     End
Offline TPS
  •  2,627 2,627
Re: CNC Lathe turret tool changer help?
« Reply #1 on: October 09, 2015, 03:17:17 AM »
i have written down a small test script, not tested:
Code: [Select]
Sub Main()
' TPS 09.10.2015
' simple Test for Toolchange
' pin2 is mapped to Input1
' pin3 is mapped to Input2
' pin4 is mapped to Input3
' pin5 is mapped to Input4
'get the new tool ---------------------------------------------------------------
tool = GetSelectedTool()
' nothing to do
   END
End If
Dim ActTurretPos as long
ActTurretPos = 0
   While ActTurretPos <> tool
      ActTurretPos = GetTurret()
   Wend
   Message("Tool " & tool & " Loaded")
   SetCurrentTool( tool )
End Sub
'function to get the actual turret positiom
Function GetTurret() As Long
GetTurret = 0
    If IsActive(Input1) Then
        GetTurret = GetTurrent + 1
    End if
        GetTurret = GetTurrent + 2
    End if
        GetTurret = GetTurrent + 4
    End if
        GetTurret = GetTurrent + 8
    End if
End Function
Regards Thomas
Offline mike^3
  •  116 116
« Reply #2 on: October 09, 2015, 07:46:58 AM »
Hi Thanks for the response, that does not seem to work....
Offline TPS
  •  2,627 2,627
« Reply #3 on: October 09, 2015, 07:51:00 AM »
so what is happening,
can you see Input1 - Input4 changing in diagnostic screen,
when it rotates ?
Thomas
Offline mike^3
  •  116 116
« Reply #4 on: October 09, 2015, 07:52:58 AM »
Hello,
I can see the 4 inputs, but your code seems off, you are only looking for one input for each tool change, input1
look at your code ;)
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 09, 2015, 07:53:46 AM »
found a mistake in my code:
Code: [Select]
Sub Main()
' TPS 09.10.2015
' nothing to do
   END
End If
ActTurretPos = 0
   Wend
End Sub
GetTurret = 0
        GetTurret = GetTurret + 1
    End if
    If IsActive(Input2) Then
        GetTurret = GetTurret + 2
    End if
    If IsActive(Input3) Then
        GetTurret = GetTurret + 4
    End if
    If IsActive(Input4) Then
        GetTurret = GetTurret + 8
    End if
End Function
copy and paste error
Offline TPS
  •  2,627 2,627
« Reply #6 on: October 09, 2015, 07:56:19 AM »
pls copy code again, did an other change.
Code: [Select]
Sub Main()
' TPS 09.10.2015
' nothing to do
   END
End If
ActTurretPos = 0
   Wend
End Sub
GetTurret = 0
    End if
    End if
    End if
    End if
End Function
« Last Edit: October 09, 2015, 07:58:26 AM by TPS »
Offline mike^3
  •  116 116
« Reply #7 on: October 09, 2015, 08:01:45 AM »
Seems to work, can you add a time out incase it doesnt see the code?
And It still would need a deactivate output 6, so the turret stops LOL
Offline mike^3
  •  116 116
« Reply #8 on: October 09, 2015, 08:02:21 AM »
I mean see the input, (so turret does just keep spinning and spinning and spinning)
 ;D
Offline TPS
  •  2,627 2,627
« Reply #9 on: October 09, 2015, 08:14:41 AM »
ok,
here with DeActivate(Output6) and timeout,
hope it works.
Code: [Select]
Sub Main()
' TPS 09.10.2015
' nothing to do
   END
End If
ActTurretPos = 0
Starttime = Timer
      Akttime = Timer
      If Akttime - Starttime > 20 then 'Timeout 20s
       Message("Turret timeout")
       End
      End if
   Wend
End Sub
GetTurret = 0
    End if
    End if
    End if
    End if
End Function
