Hello Guest it is April 25, 2024, 12:39:37 PM
Author Topic: A new Tool Table for Mach4  (Read 4127 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
« on: October 05, 2015, 03:48:53 PM »
Well still on the quest of making my custom copy of mach4 I needed a more indepth tooltable, I wanted to be able to select a tool from a library and mach4 load all the params I needed.
for Instance I use the mdi panel a lot and do a fair bit of by eye milling so If I decide I want to change tool then mach will change all the spindlespeed - feedrates etc for me.
So I created this for a start and can develop further as needed.
And of course you can have a copy too.  ;)
The Script is Here  http://www.machsupport.com/forum/index.php/topic,30973.0.html
The Setup and Usage Video Here  https://youtu.be/qxKroGC5a1M
DazTheGas
