Hello Guest it is April 25, 2024, 04:53:10 AM
Author Topic: Need Help for USB plugin for Mach3  (Read 3936 times)
« on: October 04, 2015, 02:12:45 PM »
Hi
I need help to create USB plugin. I am using SDK 2.62. and i tried to buid but i got some bunch of error's.
can one please help me, which kinda of error is this?
Code: [Select]
1>------ Build started: Project: MachDevice, Configuration: Debug Win32 ------
1>Build started 10/4/2015 11:38:55 PM.
1>InitializeBuildStatus:
1>  Touching "Debug\MachDevice.unsuccessfulbuild".
1>Midl:
1>  All outputs are up-to-date.
1>ClCompile:
1>  stdafx.cpp
1>  G100Part.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Part.cpp': No such file or directory
1>  G100Helpers.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Helpers.cpp': No such file or directory
1>  G100Handler.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Handler.cpp': No such file or directory
1>  G100Enumerator.cpp
1>c1xx : fatal error C1083: Cannot open source file: '..\g100LIBRARY\src\G100Enumerator.cpp': No such file or directory
1>  XMLProfile.cpp
1>c:\cnc\mach3development\sdk.2.62\g100io\xmlprofile.cpp(55): warning C4996: '_itow': This function or variable may be unsafe. Consider using _itow_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
1>          c:\program files\microsoft visual studio 10.0\vc\include\stdlib.h(645) : see declaration of '_itow'
1>  MyHandler.cpp
1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): error C3500: invalid ProgID 'ShockwaveFlash.ShockwaveFlash'
1>c:\cnc\mach3development\sdk.2.62\machincludes\mach4view.h(18): fatal error C1103: fatal error importing progid: 'ShockwaveFlash.ShockwaveFlash'
1>  Monitoring.cpp
1>  MachDevImplementation.cpp
1>  MachDevice.cpp
1>  LocalIPQuery.cpp
1>  GRexControl.cpp
1>  G100General.cpp
1>  G100FLASHCONFIG.cpp
1>c:\cnc\mach3development\sdk.2.62\g100io\g100-structs.h(1): fatal error C1083: Cannot open include file: 'g100.h': No such file or directory
1>  G100Config.cpp
1>  Generating Code...
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:09.59
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
i was trying SDK.2.62\g100IO code.
Please help me with this.
