Hello Guest it is April 23, 2024, 03:30:04 AM
Author Topic: Machine status light  (Read 13699 times)
« on: October 04, 2015, 09:43:40 AM »
Good Morning to all. Today i could write a brain which enables a green led when g code running, BUT I need a little help from someone who could help me to write a brain which triggers an outpout when i press feedhold on mach3 and than this output would flash the yellow led on my machine stack light. Also another brain for when i click on stop, machine's Red  led active and when reset e-stop clicked red led is flashing.
Thank you in advance
« Reply #1 on: October 04, 2015, 10:03:33 AM »
Hi, as an example. Have a look at the one on CS-Labs website. I have it running on my machine without any problems.
http://www.cs-lab.eu/en/index.php?m=article&s=main&aid=131&uinfo=Macro_for_A_Signal_Tower
Alan
Re: Machine status light
« Reply #2 on: October 04, 2015, 11:29:26 AM »
Thank you alan, but i don't have this device. I have a pokeys56U
Offline Davis Patch
  •  1 1
  • i say love, i say war.
    • Casinority
« Reply #3 on: January 08, 2016, 10:51:22 AM »
Alan, thank you, for me that was useful link.
especially ip-m type, searched a lot about this and ip-m/s.
Nothing ever comes to one, that is worth having, except as a result of hard work.
Booker T. Washington
« Reply #4 on: January 09, 2016, 09:03:22 AM »
Have you assigned the buttons (inputs) and the lights (outputs) in mach3?
You can use OEM triggers for the buttons if you are using a button panel.
You can use brains or you can use a macropump.
Same goal achieved in the end.
Rob
« Reply #5 on: November 15, 2017, 08:45:09 AM »
I can't acess the link, i need the answer the OP wanted.
Could LED be used, and which one ?
