Hello Guest it is April 24, 2024, 05:32:40 PM
Author Topic: Mach3 Probe HELP  (Read 4461 times)
Mach3 Probe HELP
« on: October 04, 2015, 03:48:23 AM »
Hello
i need your help a little please .. i have a problem with my Mach3 Probe ... to start with i made my own probe and everything it worked fine the LED light was green when the torch touched the plate and the VBscript worked fine as well when i clicked on "ref all home" .. but heres the problem when i try to work on a file on Mach3 the probe doesnt work at all .. its like i didnt even activated it :( i tried to change the vbscript and many other things but nothing worked .... i need help if you could .. as soon as possible
thanks in advance.
Mach3 Probe HELP
« Reply #1 on: October 04, 2015, 08:53:39 AM »
Hi, have you assigned the probe in ports and pins?
Alan
Re: Mach3 Probe HELP
« Reply #2 on: October 05, 2015, 03:06:13 AM »
Yes i assigned it to posrts and pins
« Reply #3 on: October 05, 2015, 05:26:38 AM »
Attach your xml file and a gcode file your trying to use.
What program  are you using to generate the gcode for the plasma?
« Reply #4 on: October 05, 2015, 05:40:46 AM »
here it is ... and i use LazyCam
