Hello Guest it is April 19, 2024, 09:27:42 PM
Author Topic: Juddering X Axis even without running  (Read 1783 times)
« on: September 24, 2015, 10:46:08 AM »
Hi
My machine has started to judder back and forth when I enable my drives by pressing Reset on the Mach3 screen.
It is similar to the autotune process that is used by CS-LABS Plugin Controller for CSMIO IP/A.
The axis is only moving back and forth approximately 100 pulses of the 10000 pulse per motor rev. I can jog the axis while this is happening, but the juddering continues.
After a minute the juddering settles down and things seem OK, until I then move the axis again and juddering starts once more.
It wasn't doing this before, but I have been playing the settings a lot!
I think it may be a tuning or mach3 config problem but has anyone got ideas on where to look first?
Many thanks
Mark
Re: Juddering X Axis even without running
« Reply #1 on: September 24, 2015, 01:58:21 PM »
That sounds like a servo tuning issue, either in the drive itself or in the IP-A plugin.
The only other thing I can think of, that it could be, is an encoder issue.
