Hello Guest it is April 24, 2024, 11:50:57 AM
Author Topic: Lcam 2.0...  (Read 65300 times)
Re: Lcam 2.0...
« Reply #80 on: November 22, 2007, 10:06:38 AM »
Your video demonstrates the cam can generate g-code to write text on a plane. Is there any way to write text on a wheel with CNC milling machine? Thanks, Xavier
Re: Lcam 2.0...
« Reply #81 on: January 24, 2008, 10:04:01 AM »
Hi, I am new to cnc. Purchased a small 21X12X3 hobby mach om ebay and Mach3.
I do a lot of scroll sawing and was wondering, will LC pro handle my scroll saw plans that I scan into Designcad and save as R12 DXF file? Or should I buy a higher end cam package?
Thanks formn a novice.
Steve in WV
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lcam 2.0...
« Reply #82 on: January 24, 2008, 02:13:43 PM »
Hi, Steve
LC should work fine, The Pro ver. adds Offset's, Pocketing and Turn Features.
Thanks, Chip
Re: Lcam 2.0...
« Reply #83 on: August 16, 2008, 03:32:43 AM »
Morning,
i have problems with the actual version of LazyCam 3, the mill compensation
doesnt run correctly by me !
i downloaded a older version (2.02) and the compensation work mutch better.
Do you have an idee, bug, bad usage of me ?
Fabrice
______________________________________________________
News : i found one reason : no right tool im Mach3 ! now run better.
« Last Edit: August 16, 2008, 03:45:18 AM by Fab6657 »
HOW TO ADDING G28 CODE ON LAZYCAM?
« Reply #84 on: November 12, 2014, 10:51:47 AM »
Please to help me!
i just want to know how i can make the lazycam adding RETURN TO HOME POSITION after finished the project!
