Hello
Guest
it is
April 23, 2024, 10:40:50 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
CS-Lab
X axis limits switch triggering during homing sequence Mach 4
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: X axis limits switch triggering during homing sequence Mach 4 (Read 2962 times)
dandonegan
27
on:
September 13, 2015, 03:00:36 PM »
I am having trouble homing my X axis with my new CSMIO/IP-M runing Mach 4. The axis is set up with a positive and negative limit switch. I am also using the negative limit switch as the home reference switch. When I home the axis I am getting an X axis limit switch tripped message and the machine goes into E stop.
I believe that this is a Mach 4 plug-in problem. I am under the impression that the homing sequences handled by the plug-in.
Does anyone have an idea to solve this?
dan
Logged
Carnoustie, Scotland
Re: X axis limits switch triggering during homing sequence Mach 4
Reply #1 on:
September 14, 2015, 06:07:47 AM »
In Mach3 on General config page there is an option called Home Switch Safety, setting that to Off (I think) will allow you to share limit and home switches.
Not sure if there is anything similar in Mach4 though.
Logged
Print
Pages:
1
Go Up
« previous
next »
