Hello Guest it is April 25, 2024, 07:41:48 AM
Author Topic: Significant Problem - Mach4 freeze on M codes  (Read 11556 times)
Re: Significant Problem - Mach4 freeze on M codes
« Reply #10 on: October 30, 2015, 03:07:18 PM »
There are updates happened internally that are not yet uploaded on the main page. sorry I was in the impression they were there. here is the link to download http://www.vitalsystem.com/portal/temp/ArcProIntegra-1.06.zip
Based on our internal testing, we do not observe the gcode line skipping issue any more.
If you do see any issues please provide the following:
zipped profile folder
gcode program and line number where you see the issue
copy of custom screens (if any)
any other plugin aside from default mach4 plugins
will appreciate if you provide brief to the point info so we can assist you better. long essays just makes the job even harder.
