Hello
Guest
it is
April 20, 2024, 01:42:16 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Tangent Corner
Tangent Corner
PC Help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PC Help (Read 8290 times)
Overloaded
4,922
PC Help
on:
August 01, 2015, 10:50:46 PM »
Hello folks, I could use some advice on fixing my desk pc.
It has somehow gotten infestered with some sort of ***ware that plugs in little popup boxes all over the text on this forum topics.
Really slows me down too.
I left my pc on and connected overnight and now have this mess.
Anyone know a proven way to fix it ?
Thanks if you can help,
Russ
Logged
BR549
6,965
Re: PC Help
Reply #1 on:
August 02, 2015, 12:06:49 AM »
RUss you have a walware attatck can you back up to an earlier waypoint in windows. Then run a good antimalware software to remove it. OR you may have a look at your installs/ipdates record and delete anything loaded in say the last week or 2. They may have very familar and officail sounding names. Just delete them 1 at a time until the problem dissapears.
Just a thought(;-) TP
Logged
Overloaded
4,922
Re: PC Help
Reply #2 on:
August 02, 2015, 06:30:33 AM »
Hi TP,
where do I find the "installs/update record" ?
I did run a windows scan which took over 5 hrs, found a couple trojans, removed them but no fix on the mess mentioned.
Also, do you know of a "good" malware remover SW ? ?
Logged
Rkjohn
65
Re: PC Help
Reply #3 on:
August 02, 2015, 10:43:23 AM »
This works better then any I have used for this kind of problem.
Spy Humter
http://www.enigmasoftware.com/products/spyhunter/
Logged
BR549
6,965
Re: PC Help
Reply #4 on:
August 02, 2015, 02:44:08 PM »
Russ go to the Control panel then uninstall /change programs. Sort the list by install date. Delete anything YOU did NOT install. ONCE you get it back up THEN create a restore point So that in the future if it happens again you can simply restore back to a known waypoint.
Just a thought, (;-) TP
Logged
Overloaded
4,922
Re: PC Help
Reply #5 on:
August 08, 2015, 12:28:15 PM »
Hey TP,
nothing shows up there. also tried a restore to last month ... no fixie.
The SpyHunter seems to have worked, found a bunch of junk.
Just hope it didn't load a bunch of it's own.
Much better .... for now.
Thanks guys,
Russ
Logged
Rkjohn
65
Re: PC Help
Reply #6 on:
August 08, 2015, 12:43:49 PM »
Go to internet options & disable downloads in security folder. That will help stoping some of the crap coming in.
Logged
Print
Pages:
1
Go Up
« previous
next »
