Hello Guest it is April 25, 2024, 07:39:53 AM
Author Topic: Z axis running in reverse  (Read 8358 times)
« on: July 26, 2015, 08:41:37 PM »
Need some help if you please. I am attempting to run my first project on Mach 3 and when my router begins to run it slams into my table. (Good thing I have a spoil board) I have narrowed the issue down to the Z axis being programmed in reverse but am unsure how to correct it.
 Help please...
Caution: Do not reach into running equipment
  •  9,199 9,199
Re: Z axis running in reverse
« Reply #1 on: July 27, 2015, 03:44:47 AM »
If you have your machine Z axis direction wrongly set then...
Config / Ports & Pins / Motor Outputs - change the 'Dir Low Active' state for your Z axis (cross or tick) then click Apply.
That will change the Z axis direction.
