Hello Guest it is April 16, 2024, 03:55:21 PM
Author Topic: Z Axis  (Read 6678 times)
Z Axis
« on: July 25, 2015, 10:36:18 PM »
I am unable to control my Z Axis. When I start the machine to cut a file the Z axis lowers, but wont stop, it wants to continue in a downward direction.
Has anybody got any ideas?
Regards
Terry
 :D
  •  9,197 9,197
Re: Z Axis
« Reply #1 on: July 26, 2015, 05:29:06 AM »
Hi Terry,
Just my thoughts...
If the Z axis DRO continues counting down while the axis is on walkabout then the chances are that the problem lies in your Gcode.
If the Z axis DRO continues counting both up and down while the axis is on walkabout then I would suspect that the axis direction signal is not being properly recognized by the controller.
If the Z axis DRO stops counting while the axis is on walkabout then you need to look at your driver hardware.
