Hello Guest it is April 25, 2024, 07:39:01 PM
Author Topic: Can't get plasma torch to move  (Read 2653 times)
« on: June 06, 2015, 10:01:58 AM »
I had to replace mu computer and now I can not get my torch to move. Did the DMI up down test but got nothing. The machine is engaged and the screen says it is moving but got no physical movement. I have checked my device mgr. Tried both EPP and ECP, checked all wiring and still have nothing. I have attached the origianl xml that I used to get the machine to run. All suggestions are appriciated.
Re: Can't get plasma torch to move
« Reply #1 on: October 06, 2015, 06:55:43 PM »
Hi! could you find a solution for this problem?
we have a CNC ROUTER with a plasma cutter, we have a problem when we work with the plasma profile, the motors not move properly in all axis. When we work with the mill profile , we don't have any problem and the machine works properly. Can you help us?
Thanks.
