I'm trying to set up CV control, the Stop CV on angles > 89 degrees it would go to Exact stop but angles less than 89 degrees it would keep the constant velocity. When I go to the General Configuration screen I Tick the Stop CV on angles > and then try change the degrees from 0 to 89, but it will not change, I can highlight the 0 in the box but cannot change it. Or have I been reading this all wrong and you have to manually change the Constant velocity to Exact stop when I want to cut 90 degree corners?
If this will not work and I'm way wrong is there a way to enable the CV mode button on the screen, that way I could cut two tool paths, one for right angles and then one with Constant velocity instead of having to go into General Configuration and change it. I find if I leave it on Exact stop it extends the cutting time.
