Hello Guest it is April 26, 2024, 01:51:26 AM
Author Topic: Setting Mach 3 withe chinese bob  (Read 3462 times)
« on: May 22, 2015, 06:43:26 PM »
My first cnc project , its a scaled up version of the chinees 20/30router.
It is working fine but the following is puzzling me.
Y & Z are set to 80 steps and the X to 320.
All the motors and dip settings are the same also the screw pitch(lead)
The slides are moving as D.R.O.
Am i missing somthing
bpoolrock
Re: Setting Mach 3 withe chinese bob
« Reply #1 on: October 12, 2015, 11:04:20 AM »
if your stepper drives have dipswitches, re flip them.  I have found that sometimes they do not rock all the way and make the connection.
your Y and Z seem a bit low.  Ok alot low.  I am assuming that you are in metric native units.   What pitch are your lead screws?  1.9 degree steppers?  and micro stepping of the stepper drives?
  •  9,199 9,199
« Reply #2 on: October 12, 2015, 12:47:27 PM »
Go to the Settings screen and click on Set Steps per Unit (bottom left).
Follow the instructions and repeat for each axis - this should tell you the correct steps per unit you should have set in Motor Tuning for each axis.
« Reply #3 on: October 12, 2015, 07:49:03 PM »
Tweakie,  it has been years since I have used the default screen set....... I totally forgot about that setting.  Wow.... relearned something today.  I always have done it manually.  I guess I am a control freak.
