Hello Guest it is April 24, 2024, 09:58:16 AM
Author Topic: Probe Script  (Read 28573 times)
Re: Probe Script
« Reply #10 on: May 21, 2015, 06:57:15 AM »
Thanks TPS.
but i tried the below and get script error.
Code "G31 F"&Feed & " X"&NegMove
Kenneth
Offline TPS
  •  2,505 2,505
Re: Probe Script
« Reply #11 on: May 21, 2015, 07:02:33 AM »
your code:
my code:
Code "G31 F" & Feed & " X" & NegMove
i never figured out when you have to make spaces and when not, so i do them allways.
« Last Edit: May 21, 2015, 07:09:44 AM by TPS »
Re: Probe Script
« Reply #12 on: May 21, 2015, 07:13:09 AM »
Thanks Daniell and TPS. this is what i got and works !
didn't know about spaces. Thanks TPS
'probing = XY ID
'probe dia. = tapered till tip - - tip .104"
NegMove = -10
PosMove = 10
Feed = 6
Code "G31 F" & Feed & " X" & NegMove           'X axis
While IsMoving()
Wend
SetOEMDRO(800,0)
Code "G00 X.2"
While IsMoving()
Wend
Code "G31 F" & Feed & " X" & PosMove
While IsMoving()
Wend
Xdro = GetOEMDRO(800)
SetOEMDRO(800,Xdro/2)
While IsMoving()
Wend
Code "G00 X0"
While IsMoving()
Wend
Code "G31 F" & Feed & " Y" & NegMove          'Y axis
While IsMoving()
Wend
SetOEMDRO(801,0)
Code "G00 Y.2"
While IsMoving()
Wend
Code "G31 F" & Feed & " Y" & PosMove
While IsMoving()
Wend
Ydro = GetOEMDRO(801)
SetOEMDRO(801,Ydro/2)
Code "G00 Y0"
End
Kenneth
