Hello Guest it is April 24, 2024, 10:01:34 PM
Author Topic: Probe Script  (Read 28576 times)
Probe Script
« on: May 21, 2015, 05:50:36 AM »
below is the code i use to probe IDs. i like to know how to
use feed move. i want to be able to change the feed at the top instead
throughout the script. is this possible ? i tried Ffeed, but it laughed at me.
Thanks for any help !
NegMove = -10
PosMove = 10
Feed = 6
'probing = XY ID
'probe dia. = tapered till tip - - tip .104"
NegMove = -10
PosMove = 10
Code "G91 G31 F6 X"&NegMove            'X axis
While IsMoving()
Wend
SetOEMDRO(800,0)
Code "G00 X.2"
While IsMoving()
Wend
Code "G31 F6 X"&PosMove
While IsMoving()
Wend
Xdro = GetOEMDRO(800)
SetOEMDRO(800,Xdro/2)
While IsMoving()
Wend
Code "G90 G00 X0"
While IsMoving()
Wend
Code "G91 G31 F6 Y"&NegMove            'Y axis
While IsMoving()
Wend
SetOEMDRO(801,0)
Code "G00 Y.2"
While IsMoving()
Wend
Code "G31 F6 Y"&PosMove
While IsMoving()
Wend
Ydro = GetOEMDRO(801)
SetOEMDRO(801,Ydro/2)
Code "G90 G00 Y0"
End
Kenneth
Offline dude1
  •  1,253 1,253
Re: Probe Script
« Reply #1 on: May 21, 2015, 06:09:24 AM »
Code "F10"         'slow down feedrate to 10 ipm
Re: Probe Script
« Reply #2 on: May 21, 2015, 06:12:41 AM »
Thanks daniell,
if i put that at the beginning, after it hit G00 the rest of the
script will be in G00 mode. and i'm already going 6imp.
Thanks again
those aren't feed moves, but axis moves
Kenneth
Offline dude1
  •  1,253 1,253
Re: Probe Script
« Reply #3 on: May 21, 2015, 06:20:40 AM »
Code "G4 P0.25"  'pause  might pay to add pause in to you know its working properly and to give time for the Estop to be hit before the next move
Re: Probe Script
« Reply #4 on: May 21, 2015, 06:24:59 AM »
i'm trying to change the feed at the top.
like ;
Feed = 6
then ;
Code "g31 F[Feed] X"&PosMove
that way i can change the feed in one area. is this possible ?
or even have two feeds
Feed1 = 6
Feed2 = 10
Kenneth
Offline dude1
  •  1,253 1,253
Re: Probe Script
« Reply #5 on: May 21, 2015, 06:31:42 AM »
feed is Code "F"
« Last Edit: May 21, 2015, 06:35:15 AM by daniellyall »
Offline dude1
  •  1,253 1,253
Re: Probe Script
« Reply #6 on: May 21, 2015, 06:34:26 AM »
look how the Code"F' is done in this code
Rem   VBScript To probe In the z axis
If GetOemLED(801) Then            'check if English Units
   If GetOemLED(16)<>0 Then 'Checks for machine coordinates
         code "(Please change to working coordinates)"
   Else
   If GetOemLed (825) <> 0 Then       'check to see if the probe is already grounded or faulty
      Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
   Else
      Code "G4 P1"         'pause 1 seconds to give time to position probe plate
      PlateOffset = GetUserDRO(1151)   'get plate offset DRO
      CurrentFeed = GetOemDRO(818)    'get the current feedrate to return to later
      Rem Probe In the z direction
         ZNew = GetDro(2) - 6         'probe move to current z - 6 inches
         Code "G31Z" &ZNew
         While IsMoving()      'wait for probe move to finish
         Wend
         ZNew = GetVar(2002)       'read the touch point
         Code "G0 Z" &ZNew +.1      'move back  +.1 to hit point incase there was overshoot +.1
         While IsMoving ()
         Wend
      Rem End add lines
      Code "F2"         'slow down feedrate to 2 ipm
      ZNew = GetDro(2) - .25      'probe move to current z - .25 inches
      Code "G31Z" &ZNew
      Wend
      Code "G0 Z" &ZNew       'move back to hit point incase there was overshoot
      While IsMoving ()
      Wend
      If PlateOffset <> 0 Then
         Call SetDro (2, PlateOffset)   'set the Z axis DRO to  plate thickness
         Code "G4 P0.25"       'pause for Dro to update.
         'ZNew = PlateOffset + 3.6315   'calc retract
         'Code "G0 Z" &ZNew       'put the Z retract height you want here
         Code("G53G0Z-0.5")      'Z retract
         While IsMoving ()
         Wend
         Code "(Z axis is now zeroed in English Units)"    'puts this message in the status bar
      End If
      Code "F" &CurrentFeed       'returns to prior feed rate
   End If
   End If
Else                                             'This portion of script is for Metric Native Units
   Else
      Code "F300"         'slow down feedrate to 300 mmpm
         ZNew = GetDro(2) - 150      'probe move to current z - 150 mm
         Code "G31Z" &ZNew
         Wend
         Code "G0 Z" &ZNew + 3      'move back  + 3 mm to hit point incase there was overshoot + 3 mm
         While IsMoving ()
         Wend
      Rem End add lines
      Code "F50"         'slow down feedrate to 50 mmpm
      ZNew = GetDro(2) - 6      'probe move to current z - 6 mm
      Code "G31Z" &ZNew
      Wend
      While IsMoving ()
      Wend
         'ZNew = PlateOffset + 50      'calc retract
         Code("G53G0Z-12")
         While IsMoving ()
         Wend
         Code "(Z axis is now zeroed in Metric units)"    'puts this message in the status bar
   End If
      Code "F200"
      Sleep 100
   End If
End If
Re: Probe Script
« Reply #7 on: May 21, 2015, 06:40:55 AM »
i understand. but to change your feed you'll have to go thru the script
and change each one. i understand that feed is modal and if i put
F6 at the top in would feed at 6 till it gets to G00 then ALL feeds will be G00
from there. "I" want to be able to change the feed in ONE place.
Is This Possible ?
Kenneth
Offline TPS
  •  2,505 2,505
Re: Probe Script
« Reply #8 on: May 21, 2015, 06:45:28 AM »
like ;
Feed = 6
then ;
Feed1 = 6
Feed2 = 10
Feed1 = 6
Feed2 = 10
Code "G31 F" & Feed1 & " X" & PosMove
Code "G31 F" & Feed2 & " Y" & PosMove
« Last Edit: May 21, 2015, 06:57:36 AM by TPS »
Offline dude1
  •  1,253 1,253
Re: Probe Script
« Reply #9 on: May 21, 2015, 06:53:58 AM »
do what TPS says
« Last Edit: May 21, 2015, 06:55:56 AM by daniellyall »
