Hello Guest it is April 26, 2024, 06:10:42 AM
Author Topic: ports and pins ....outputs .. random numbers filled in automatically  (Read 2892 times)
the charge pump will not take any pin other than 17 and output 1 will not take any pin other than 17.. so if i want to use the relay on the c41 board, i cannot use the charge pump which is unsafe...
when im tryinhg to put a number in one of the output boxes, any box...it bounces from that box to a random box and fill in a random pin number on its own...
it also locks out the slider to right and i cannot move it..i have to close out ports and pins then restart it.. if i double click in random boxes again it jumps again to anotrher box and fill in a random number and locks out the slider...please let me know if i can talk to someone or where to post this. i downloaded a trial version on my laptop and its doing the same as my mill comp both on windows 7 32 bit.
RET SSG Gonzales
5th SFG
DE OPPRESSO LIBER
