Hello Guest it is March 29, 2024, 10:34:31 AM
Author Topic: Reseting the Z height with THC  (Read 6196 times)
« on: May 15, 2015, 11:27:30 AM »
When cutting a row of small part I'd like to adjust the Z height to what the THC as decided was .06 inches off the last cut instead of use the standard probe/limit switch function. I thought inserting "G92 Z0.60 right at the end of each cut would do the trick but it doesnt seem to be working. Below is a section of my code. What am I missing?
Code: [Select]
N0010 %
N0020 G20 G53 G90
N0030 G0 Z .75
N0040 G0 X-.395 Y0.0
N0050 Z .18
N0060 M03
N0070 Z .06
N0080 G1 F75.
N0090 G90 X-.475
N0100 G3 I.475 J0.0
N0110 X-.4746 Y-.02 I.475 J0.0
N0120 G1 X-.3947 Y-.0166
N0130 G0
N0140 G92Z0.06
N0150 M05
N0160 G0 Z0 .75
N0170 G0 X-1.355 Y0.0
N0180 Z .18
N0190 M03
N0200 Z .06
N0210 G1 F75.
N0220 X-1.275
N0230 G2 I1.275 J0.0
N0240 X-1.2748 Y.02 I1.275 J0.0
N0250 G1 X-1.3548 Y.0213
N0260 G0
N0270 G92Z0.06
N0280 M05
N0290 G0 Z0 .75
Re: Reseting the Z height with THC
« Reply #1 on: June 30, 2015, 07:56:43 PM »
#100 = 0.06
G20 G90
G0 Z .75
G0 X-.395 Y0.0
G0 Z .18
M03
G0 Z#100
G1 X-.475 F75.
G3 I.475 J0.0
G3 X-.4746 Y-.02 I.475 J0.0
G1 X-.3947 Y-.0166
G0 Z#100
G0 Z0.75
G0 X-1.355 Y0.0
G0 Z0.18
G0 Z#100
G1 X-1.275 F75.
G2 I1.275 J0.0
G2 X-1.2748 Y.02 I1.275 J0.0
G1 X-1.3548 Y.0213
G0 Z#100
M05
G0 Z0 .75
« Reply #2 on: June 30, 2015, 09:48:35 PM »
This should work BUT if you are loosing the Z positions then you are stalling the Z motor under THC control . You need to slow the Z down some so it does NOT stall.
N0060 M03
N0070 Z .06
N0080 G1 F75.
N0090 G90 X-.475
N0100 G3 I.475 J0.0
N0130 M5  ( shut off the torch)  <<<---------------------
N0140 G92 Z0.060   ( Reset Z to .060)  <<<--------------------
N0160 G0 Z0 .75  ( raise to Safe Z)
N0180 Z .18
N0190 M03
« Last Edit: June 30, 2015, 09:50:09 PM by BR549 »
« Reply #3 on: July 02, 2015, 01:40:45 PM »
Thanks for the response Guys. I'll try them out this Weekend.
« Reply #4 on: July 05, 2015, 05:07:39 PM »
That did it! Just had to issue G92Z0.06 right after M5 instead of before.
Thx much.
