Hello Guest it is April 26, 2024, 10:30:11 AM
Author Topic: DRO for Feedrate set by GCode  (Read 4676 times)
Offline SSPW
  •  26 26
« on: May 13, 2015, 11:32:09 AM »
Can somebody tell me which DRO number/name the feed rate set by gcode is?
I want the one with the arrow in the attached pic.
Re: DRO for Feedrate set by GCode
« Reply #1 on: May 13, 2015, 11:39:25 AM »
Probably 818.
« Reply #2 on: May 13, 2015, 11:40:39 AM »
Maybe ?
Russ
« Reply #3 on: May 13, 2015, 11:43:46 AM »
I bet Gerry's right ... I see 818 in the list too.
Russ
Offline SSPW
  •  26 26
« Reply #4 on: May 13, 2015, 11:51:25 AM »
I used list on the wiki too.
But, In my brain editor, i pick DRO, and 18 and 818 are not listed! Actually 18 is listed, but as G92A Z off!
« Last Edit: May 13, 2015, 11:53:06 AM by SSPW »
« Reply #5 on: May 13, 2015, 12:17:21 PM »
Remember guys the DROs were revamped at one point to basically combine all the DROs  (dro,oemdro,userdro) and all the old stuff is still there as well. Can be a big mess if you are not carefull.
Just a thought, (;-) TP
« Reply #6 on: May 13, 2015, 12:23:34 PM »
Good tip TP.
So then, for tha OP, where is the dro for use in a Brain ?
Offline SSPW
  •  26 26
« Reply #7 on: May 13, 2015, 12:30:13 PM »
Ok! So a bunch of stuff is not listed under DRO.
But it has a "Use DRO Number" and says 1000-225 in valid
So i tried 818 anyways, and it works! LOL
BR549, i agree, Mach3 is a big mess, in terms of documentation!
You gotta be willing to search a lot more than you should have to, read a lot, here other places and watch a lot of youtube, and spend a crap load of time piecing the crumbs together to get a piece of bread!
« Reply #8 on: May 13, 2015, 12:54:22 PM »
ha ha, imagine that ! ... I tried that as well, posted the finding, then saw the 1000-2255 thing and deleted my post.
Then actually tried 818 anyway it it worked here as well !
At least we were on the same page lol.
Russ
Good job !  :)
