Hello Guest it is November 22, 2026, 01:27:40 PM
Author Topic: ESS Homing Offset Sorted  (Read 44969 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
« on: May 11, 2015, 05:43:13 PM »
Well got fed up waiting for the slow boat bringing parts I require so sat and and worked out this.
http://youtu.be/lYQHRWbwqS4
Code: [Select]
<<PLC Script>>
if (x_enable_offset == "true" and y_enable_offset == "true" and z_enable_offset == "true") then
    if (offset_applied == "false") then
        xoffset = mc.mcAxisGetHomeOffset(inst, 0);
        yoffset = mc.mcAxisGetHomeOffset(inst, 1);
        zoffset = mc.mcAxisGetHomeOffset(inst, 2);
        mc.mcAxisSetPos(inst, 0, 0.00);
        mc.mcAxisSetPos(inst, 1, 0.00);
        mc.mcAxisSetPos(inst, 2, 0.00);
        mc.mcCntlGcodeExecuteWait(inst, "G00 X"..xoffset.." Y"..yoffset.." Z"..zoffset);
        offset_applied = "true";
    end
end
<<Signal Script>>
if (sig == mc.OSIG_HOMED_X) then
    if (state == 1) then
        x_enable_offset = "true";
    else
        x_enable_offset = "false";
    end
end
if (sig == mc.OSIG_HOMED_Y) then
        y_enable_offset = "true";
    else
        y_enable_offset = "false";
    end
end
if (sig == mc.OSIG_HOMED_Z) then
        z_enable_offset = "true";
    else
        z_enable_offset = "false";
    end
end
<<Screen Load and Ref Home Btn >>
offset_applied ="false";
Enjoy
DazTheGas​​
Offline dude1
  •  1,253 1,253
Re: ESS Homing Offset Sorted
« Reply #1 on: May 11, 2015, 06:47:09 PM »
nice work daz you might be the next M4 go to man
« Reply #2 on: May 12, 2015, 05:09:23 AM »
Absolutely wonderful. Thank you , Thank you !!!! for your effort and great videos !!!! I haven't switched to M4 ...yet. But, your post and videos are really going to help in my decision to do so :)
Offline dude1
  •  1,253 1,253
« Reply #3 on: May 12, 2015, 05:35:43 AM »
hows this for a push I ran my big router on M4 today once I got it tuned in 0.01 mm next run 0.01 final run 0.01 the best I could get with M3 0.03 mm per 1000 moves in Z axis with a code that has a lot of speed changes 300 mm/min to 1250 mm/min same goes for X and y
