Hello Guest it is April 25, 2024, 09:12:35 PM
Author Topic: using a variable value directly in gcode  (Read 2034 times)
« on: May 03, 2015, 10:08:32 AM »
I'm having no luck executing movement from inside macro files, so I'm looking for an alternative to this macro.
Dim X As Double
X = GetVar(302)
Code "G00 X" & X
End
Is it possible to call up the value of the variable X in this way inside the macro, pass it to the main Gcode file, and then read and execute the 'G00 X &X' command in the Gcode itself, rather than unreliably from inside a macro? Absolute mayhem ensued when I tried more complicated moves from a macro, I'm looking to avoid all 'Code "G...."' statements if at all possible.
If not, would adding
'If IsMoving()
Wend'
before 'End' ensure that this line is executed properly before moving on?
M21
Re: using a variable value directly in gcode
« Reply #1 on: May 03, 2015, 02:40:18 PM »
Always use the WHile Ismoving()  / Wend after each single motion call or Group of motion calls.
« Reply #2 on: May 03, 2015, 04:24:40 PM »
Will do
