Hello Guest it is April 18, 2024, 02:48:57 AM
Author Topic: 5 axis kinematics coming soon !!!  (Read 24954 times)
  •  9,197 9,197
Re: 5 axis kinematics coming soon !!!
« Reply #10 on: April 03, 2015, 07:24:23 AM »
Thank you for the information - I look forward to seeing the demo version.
« Reply #11 on: April 03, 2015, 07:31:20 AM »
Reflection,
Not much for free exploration anymore......sometimes so much given but empty on the recieve.  :D
« Reply #12 on: April 04, 2015, 10:45:03 AM »
What format is the video I cannot play it.
« Reply #13 on: April 04, 2015, 10:59:45 AM »
Mp4
« Reply #14 on: April 04, 2015, 11:38:21 AM »
If you see the "spinning hourglass" after hitting the play button, click "pause" and wait about 10 minutes. I found the page to be incredibly slow loading.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #15 on: April 04, 2015, 11:48:57 AM »
@krw125 - I see you've painted out the bit you missed. How's the purchase going?
« Reply #16 on: April 04, 2015, 12:20:26 PM »
it will be ok for  me on monday !
i'm going to change the player for Less slowness
« Reply #17 on: April 04, 2015, 01:54:53 PM »
OK are you running the sequence in Gcode or are you jogging ? I did not see anything that could not be done from Gcode  programmed from a 3d CAM.
NOW if you can world point jog you may have kinematics if you cannot world point jog you do not have kinematics.
Just a thought, (;-) TP
« Reply #18 on: April 04, 2015, 02:13:24 PM »
Gcode is not programmed from a 3d cam.
three way to have kinematics :
  -with mdi commands for a single move
  -jogging
  -with the editor to create sequence : the plugin calcul the toolpath and load them in mach3
« Reply #19 on: April 04, 2015, 02:32:08 PM »
the fisrt video was effectively with a cad cam software to show the virtualisation of my machine, it was before i got the idea to writte le plugin. The idea came when in my work, my boss bought a 5 axis machine the DMU 75 MONOBLOCK
It was so  fun to program directly, I was not able to resist to have the same moves whitout a cad cam sofware
