Thanks, NeoTo, but I read the manual.
On the CNCAddon:
I have tried to connect a direct wire from the last GND on the wide green block, to X+ limit.
The switch does not work !
/Plugin Control/Config 56E/Pulse engine settings/ limit switch does not change color from red/green as it should.
I am using the pulse engine "dedicated 4-channel with dedicated IO" setting.
If using a switch from the Pokeys board, say IO pin 3, to GND on the Pokeys, the limit switch works correctly.
Servos jog properly ..
but I must have reliable limits, and the dedicated switches would be much better for homing and limits.
Any idea what I could do ?
I have tried both GND signals, on the OC output block, on the CNCAddon.
It seems like the IO signals simply dont work.
I also tried the pin2, GND, from motor connector 5, to dedicated limitx+.
It does not change the pin state on the plugin screen.
Like I said, the pin3 on pokey57E to GND on pokeys57E, works correctly.
Now connected to limitx-, and works correctly.
So, its only the dedicated IO I am having trouble with.
