Hello Guest it is April 25, 2024, 10:35:40 AM
Author Topic: Re: 57E + cncaddon - grounds and wiring (servo AC808)  (Read 2043 times)
« on: March 25, 2015, 10:20:28 AM »
Are the grounds 2,4,6,8 internally connected ie equal on the cncaddon ?
Ie can I connect like this
PoKeysCNCaddon (10Pin)   MCA808 X1 (DB9 male)
3  DIR   --------------------------->    1 DIR+
2  GND   -------------------------->    6 DIR-,
                                                  7 PUL-,
                                                  8 ERC-
5  STEP --------------------------->    2 PUL+
1  ENABLE --------------------------->    3 ERC+
The reason is that the nr of connections increases quite a lot, If I need to do extra lines 7,8 for each of 4 drives.
I am running out of motor data lines on the 25 pins connectors out-of-controller.
Offline NeoTO
  •  504 504
    • PoLabs
Re: Re: 57E + cncaddon - grounds and wiring (servo AC808)
« Reply #1 on: March 25, 2015, 03:56:57 PM »
Yes, GND pins are all internally connected on the PoKeysCNCaddon.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
