Hello
Guest
it is
April 23, 2024, 08:04:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
Cutting thick materials on a mill
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cutting thick materials on a mill (Read 10308 times)
bochmannfa
2
on:
March 25, 2015, 10:14:24 AM »
I'm new to cnc and am using mach 3 to run a mill on which I am cutting 3" thick Gatorfoam.
Since the bit is very long I can't seem to slow the x and y movement enough to keep the bit from breaking off at the collet.
How do I slow the x and y speed?
Logged
Tweakie.CNC
9,199
Super Kitty
Re: Cutting thick materials on a mill
Reply #1 on:
March 25, 2015, 11:58:49 AM »
Check that your Gcode uses G01 moves for the X and Y then edit the Gcode to reduce the F*********x (feedrate). Alternately, the Feed Rate Override slider can be adjusted downwards (main screen).
Logged
Reply #2 on:
March 25, 2015, 12:29:08 PM »
Consider doing multiple depth cuts and a finish cut at full depth.
Logged
bochmannfa
2
Reply #3 on:
March 27, 2015, 09:13:50 AM »
Both of those things helped a lot but I also ended up plaining the bed. It turns out I had some pretty nast high spots which were cathing the bit. I also ran into a problem when I slowed the feed rate too much. The bit melted the foam. The learning curve is pretty steep on this stuff. Thanks for the help.
Logged
Print
Pages:
1
Go Up
« previous
next »
