Hello Guest it is April 26, 2024, 06:24:05 PM
Author Topic: Yaskawa GPD 315/V7 VFD Testing Communications  (Read 6391 times)
« on: February 25, 2015, 10:57:02 AM »
I'm trying my first modbus setup and am having some trouble with addressing in Mach 3.  I've attached a pdf from Yaskawa covering command and monitor registers.
I need help with the Mach 3 communication testing.
The GPD315 VFD RS-232 port defaults to 9600 baud, 8-n-1 and is fixed.  My slave address is 1Fh.
How do I express my register values to Mach 3?
Hurco
Re: Yaskawa GPD 315/V7 VFD Testing Communications
« Reply #1 on: February 26, 2015, 12:38:06 PM »
The Modbus Configuration Screen slave address drop down lists 0-10, but I can enter larger numbers.  Do I enter decimal numbers and mach3 converts this to hex?
Hurco
